Exhaust Elbow Bellows for 2.3L 120HP GM
mnguy
I have a torn exhaust elbow bellows that I need to replace.<br />The boat is a 1985 16' open bow Stingray.<br />The engine is a 2.3L 4 cyl inline GM, sn#6916556<br /><br />Using manual: Clymer Mercruiser Stern Drive Shop Manual,<br /> 1986-1989 Alpha One and Bravo One (B742)<br /> (ISBN: 0-89287-454-6)<br /> On page 123 step 11 (for GM inline engine removal) it<br />describes "unclamping and disconnecting the exhaust<br />elbow bellows", which is a very hard rubber piece<br />that connects the smaller diameter exhaust elbow<br />coming out of the top of the engine with the larger<br />diameter exhaust pipe. There are 2 circular wire clamps<br />at the top and 2 at the bottom. This is the reason I think<br />the part is called an exhaust elbow bellows. This part is <br />in the rear of the engine compartment, at the same height <br />as the spark arrestor. <br /><br />I have tried to find the item online, but the few places <br />I've found don't show any photos/diagrams, and I want to <br />make sure I order the right part. I finally did see a<br />similar looking item in a different thread on the forum:<br />Inspecting exhause flappers<br /> http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=24;t=013002 <br />(Exhaust & Cooling.gif)<br />The part looks like item #60.<br /><br />I've tried patching the existing part with gasket sealer,<br />but that didn't hold. I tried wrapping a rag around it,<br />but the rag got soaked and still sputtered water unto the<br />engine and spark arrestor plus still chokes me with the<br />exhaust fumes.<br /><br />I went to a nearby repair shop, and we found a similar<br />looking part, but he said it was for Ford engines, not the <br />GM one, and may not work for me, so he didn't think we<br />should order it.<br /><br />So, does anyone what the correct part number is for this<br />part, where I might order it, and roughly what it would<br />cost?<br /><br />Thanks for your help, sorry if I'm not using the right terms<br />here, this stuff is still really new to me.
Re: Exhaust Elbow Bellows for 2.3L 120HP GM
This is part of your problem,...........<br /><br />To the Best of My knowledge,........<br />The 2.3l motors are Ford motors.........<br />If you Do have a GM motor,...... It's Either a 2.5l, or a 3.0l.............<br /><br />And,.........<br />Mercruiser has Never used the 2.3l Ford motor,......<br /><br />You part should be readily available......<br /><br />Ayuh,.....<br />Right here in Tommays link,.... Part # 32 - 44348, for the "New Style" exhaust,....<br />And, 70981A 3, for the "Old Style" exhaust.............. ;)
mnguy
Thanks guys. I'll return to the nearby shop with the updated info and have them order the part. And a couple of the gaskets; I'm guessing I have to acutally remove the elbow itself to replace the bellows.<br /><br />Thanks again!
Ayuh,.........<br />That's Correct............
mnguy
I've loosened the 4 hose clamps holding the bellows itself, and I am trying to remove the exhaust elbow from the <br /><br />top of the engine. There seem to be 4 bolts; 2 short ones in the front and 2 longer ones in the back. I've <br /><br />removed 3, but the fourth one is directly beneath the fiberglass boat decking and seems impossible to reach. Is <br /><br />this true, or can it be lossened with a box end wrench from behind? (It just doesn't seem possible).<br /><br />This sits on another thin part, the exhaust adaptor, that is between the top of the engine itself and the elbow. Should I be removing this piece (which includes the elbow assembly) from the top of the engine instead?<br /><br />Should I cut away part of the fiberglass boat decking to get access to the 4th bolt?<br /><br />Thanks again for the help.<br /><br />At http://www.dougrussell.com/partscatalog/collections/index.cfm?fuseaction=collectdetails&colid=04 <br /><br />I have the:<br /> 120/2.5L GM 153 I/L4 1983-1989<br /> 6229718 AND UP<br /> EXHAUST MANIFOLD AND WATER SYSTEM (USE w/2 PIECE EXH. ELBOW) <br /><br /> http://www.dougrussell.com/partscat...eaction=viewparts&colid=04&coldesc=120/2.5L % <br /><br />20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20GM%20153%20I%2FL4%201983%2D1989&index=963&block=16&BlockNum<br /><br />berList=6,7,8,5,4,15,14,10,27,31,26,30,25,29,11,35,36,37,
tommays
as far as getting to bolts welcome to good boat building 101<br /><br />i think i would do pretty much anything to avoid cutting anything that would show after the engine cover was replaced<br /><br />they make all kinds of u-shaped wrenches and a lot of times i buy one and use the torch to heat it up and make it fit ;) <br /><br />look around the frameing on the back of my boat doesent look removeable but it is they just hide the screws real good<br /><br /><br />tommays
