LinkAmerica.net
- Joined
- Jun 16, 2003
- 15
Hello,<br />I have been having an ongoing problem with my 90 OMC Cobra 5.8. I am getting water in the oil. I posted a post a while back and I am back to ask more questions. I have taken the heads off because I thought it could have a busted head gasket. Well, none of the gaskets are broke that I could tell, so I had the heads compression tested, resurfaced and put them back on with new gaskets. The heads checked out ok. I also put a new Intake Manifold on, and Edelbrock Performer because the stock manifold had a crack in it. That apparently was not the problem because it still happens. I notice another interesting thing, it only gets water in the oil if I put it in the water and run it for 20-30 mins. After rebuilding the heads, I put the earmuffs on and ran it for about an hour or so and there was no water that got in the oil. As soon as I put it in the lake, it got oil in it. I don't believe it is a cracked block because if it was, I think it would get water in the oil on the muffs, and I let the engine temp get to operating temp. So I got to thinking and maybe it was getting water in the exhaust when we backed off and made a stop. I took off the risers and looked at the exhaust flappers and they were melted and the seal was messed up. When they were closed, it did not make a seal, the edge was messed up and I could stick a screw driver between that and the pipe. I went to the marine place and they said it was a known problem but mostly happens if someone puts a different engine in the boat because it lowers the manifold closer to the water line. <br /><br />My question is this.<br />Has anyone ever heard of this happening?<br />Am I going to fix the problem with a 15 dollar part after I spent 400 dollars on a new intake and head work?<br />Please help, any info would be great. <br />Again, why would it happen only in the water and not on the muffs?<br />I also figured that in the exhause manifold was cracked, it would get water in on the hose too.<br /><br />Thanks,
