imported_wildcat
- Joined
- Jul 20, 2004
- 74
I am a newbie at all of this and I need to verify that if I pour antifreeze into the cooling hose that goes from the thermostat to the bottom of the exhaust manifold that the antifreeze will go out the exhaust hose to the prop and not into the cylinders, if the engine is not running. I have a 5.0L MPI engine. It appears that the fluid goes through the exhaust manifold, around the elbow, and does not mix with the exhaust until it reaches the aft end of the elbow. This allows gravity to ensure that the fluids drain out the prop and away from the engine.<br /><br />I have owned a waverunner for many years and if the engine is not running, the fluid will backup into the cylinders.
