i have a manifold and riser like the one shown below. i am in the process of running a thru hull exhaust and i want to know if there is enough rise and degree of angle on the riser to prevent water from flowing up the exhaust line and into the manifold (the tube for the exhaust extends about 12 more inches before the transom & the tips are right at the water line). Or, do i need to try and find a spacer to raise the riser higher into the air? the exhaust tips do have a flapper on them, but in reallity how well does that flapper work in keeping water from flowing in?
