Permatex ultra copper not available in the UK![]()
Hard to believe there isn't an alternative or have it shipped.Yes got the instructions but the sealer is not available in the uk ??
Instructions have changed since then.On inspection I notice the instructions included with the riser gaskets are dated 2008 and specify no gasket sealer to be used!
This is from the instructions that come with the risers
Change to Procedure:
Before installing a riser gasket, coat the mating surfaces of
both the manifold and the riser with a copper-based, heatresistant
gasket compound.
Examples:
Permatex Copper Spray-a-Gasket? (80697)
K&W Copper Coat? (401612)
Aerosol or brush-on applications are both acceptable.
