I am restoring a 1988 Marlin Ski Magnum. The boat is an inboard and I have it stripped to the hull and am going through everything as the boat was not running when I got it.
The exhaust manifolds look good, but the risers are looking kind of rough. I have not been able to locate a local shop to pressure test the manifolds.
I have potential access to Indmar exhaust manifolds and though the risers are shaped differently, my exhaust is being replaced and I have plenty of clearance under the doghouse, so that is not an issue.
Is there something I am failing to consider?
If the indmar parts source falls through I had also considered using Volvo exhaust manifolds. Again is there anything I am missing about the parts interchangeability?
Engine rebuild is almost done and I need to line up the next round of parts to keep this restore moving.
