Thanks. I've found a new set of the two piece type for about $750.. I know that is better than buying another long block. However, this project hole keeps getting bigger an bigger :}.
I assume one main reason for using the exhaust as part of the water discharge is to help keep the engine compartment temp down. Otherwise I would think one could easily plumb the water to each of the lower exhaust pipe? However, the rubber connectors may not be able to withstand the exhaust heat with o water?
Oh well for now just need to get the new engine here and put back in and finish up the work on the drive, floor and other items on my To do list..
