No, but you need to replace the manifolds & risers.....does this mean that I'm likely to have engine block rust-through or close to it also?
'92 Sea Ray 4.3L Merc alpha.
Your OP said "rusted through". If the manifold was indeed rusted through, the riser would not be far behind.So I got into this again tonight, and I found the exhaust manifolds did indeed look to be cracked/repaired from freezing damage, and not rust through, like I'd thought. I can find no evidence of riser damage, or block damage, none.
Why would I need to replace the risers also if they don't show signs of damage? Or was this just an assumption that you guys made from my post?
Yup, we can only give advice on what info you give us, especially when ya don't post pics......So I got into this again tonight, and I found the exhaust manifolds did indeed look to be cracked/repaired from freezing damage, and not rust through, like I'd thought. I can find no evidence of riser damage, or block damage, none.
