2stroke1971
- Joined
- Nov 8, 2009
- 210
At low RPMs, there is no noise, but pretty early on in the throttle, it starts with the lawn mower sound... It sounds pretty loud under the engine hatch, but I dont think its coming from the manifold, its been put on recently with new gaskets, and I cant feel any puffs from the port areas.
By the end of the trip, there is some water in the bilge, not enough to trip the pump on though.
I know the exhaust bellows needs replacing, when I was running in a bucket, there was a little hot water dripping out of it. Could a leak down there in the bellows cause noise up in the engine compartment? I figured since that would be under water, it wouldnt, but Im not sure.
From what I can see of the pipe, it looks okay....do they ever rust thru? The pipe leading down and out the outdrive I mean. I would have thought anyway, that any leak under the hatch would be accompanied by some water also, but even at full throttle, I see no steady drips or anything.
Thanks in advance for any ideas or suggestions.
