Exhaust Question
scott8058
Ok this is probably a dumb question but if you convert to an above water exhaust system do you gain any power on a boat like you would in a car?
5150abf
Re: Exhaust Question
An engine is an engine and anytime you free it up you gain power so I would say yes but remember you have to modify both ends of the system, you can't do just the exhaust wihtout doing something the carb/injectors.
To get more power out you have to put more gas in.
tpenfield
Not a dumb question . . . yes more power as the flow of the exhaust will be better and less power taken away from the engine.
It is difficult to say how much power, and as stated, you will be limited by what is going into the engine.
The more popular name is "thru hull" exhaust. When you do that, you need to address noise suppression, unless you want to join the go-fast, be-loud (GFBL) part of boating.
Ayuh,... I gotta disagree with the 2 posts above,...
Due to the common plenum designs of marine exhaust manifolds, the Manifolds are the chokin' point....
Goin' to thru-hull exhaust, by itself causes a Huge increase in Noise,...
'n No increase in horsepower....
Now,.... If ya throw in a set of marine Headers,....
Ya, that and some more motor modifications will build ya more horsepower....
Frank Acampora
Don't forget that there is some measure of exhaust extraction with a thru prop hub system. I would say that unless you are going to race mode like the go-fast guys it is probably a wash and wasted money.
H20Rat
I've helped a couple of guys install choice exhaust systems, and have ridden in those boats. I can't say that ANY of them have had any change in speed/hp. If anything, the thru-prop might actually flow easier, there is basically a giant vacuum sucking the exhaust out!
Chris1956
Smokingcrater is correct. As the boat moves thru the water, the exhaust is sucked thru the prop. This efficiency is as good as wide open pipes and much easier on the ears. As boats with open pipes pass my house at idle, the noise is deafening. I have developed a deep hatred of those boats and their owners.
rallyart
I've seen many dyno tests on race engines for cars and most will perform with more power going through the right muffler when compared with running a straight pipe after the header while experiencing a 10-20 dB drop in noise level. I have yet to see a sport boat that had a performance improvement by making the exhaust loud. The owners of the boats sometimes think their boat goes faster because it now 'sounds powerful' but that is not speed. Bondo's assessment is correct on actual marine headers helping but you could still flow through the prop with those installed. Usually you need to match other changes to increase air flow to realize much power increase.
bruceb58
Aren't all cars above water exhaust? :)
Straight pipes actually have lower power than a tuned exhaust system. Ask any Harley owner that switched to straight unmuffled pipes.
scott8058
Interesting thoughts to consider, thanks to all who replied!
NSBCraig
Staright pipes actually have lower power than a tuned exhaust system. Ask any Harley owner that switched to straight unmuffled pipes.
Boy is that true!
