I looked at a 1991 48 SPL today. The motor fired right up, idled good, had good flow of water from the pee tube (ran on muffs). We ran the motor in forward and reverse and let it idle for about ten minutes. Turned it off and it cranked right back up. A few minutes later i notice a thick gray goop running down the skeg. It was on both sides on the skeg coming from the area where the prop and housing meet. Does this mean there is a problem? The owner said he was told by his mechanic Johnson's do that and it was nothing more than exhaust. I did not pull the plug from the lower unit and check the oil there to see if water was mixing with oil.
Any suggestions or comments??
