Exhaust replacement Yanmar
cyn143srog
Hello, I'm mew to the forum, hopefully I'm in the right place. I have 2005 Mainship 34 with twin 240 diesels. I need to replace exhaust hoses from the motor
To the muffler am I able to do this while in the water.
Roger
welcome aboard
depends if the hoses are above the water line. are these horizontal hoses from the riser, or a vertical hose from the riser.
cyn143srog
Mostly horizontal, rises up to the motor, muffler is just slightly above water line. Exhaust discharge is below the water line. Connection is not very easy to get at. Boat is going to be on the hard in July maybe I should do it than.
Ayuh,.... Welcome Aboard,...... Any pipes below water level will flood the boat,....
