BAproject
- Joined
- Sep 2, 2009
- 276
I have placed a few posts about an engine that is running too hot. I am still puzzled and will be replacing the lower unit impeller this afternoon. I have also replace the t-stat, circ pump, hoses, and exhaust risers. Still can't figure out why running so hot (idle 175 with a 140 degree t-stat), creeps to 200 degrees under load. Did it once, shut it down and got towed back in so I didn't cause any major damage. Run off muffs int he driveway for diagnosis now
When I replace the exhaust risres there were 2 different styles of gaskets that can be used int his system (this is raw water cooled btw). The lady at the boat place gave me the gasket that has 1 large opening in the center, 2 openings (1 on port and 1 on starboard side) and then the holes that are front and back are just very small holes. She explained this is the gasket for a system that doesn't use 4" extensions off the manifold(I don't have these). I'm not sure I believe her.....
I'm really not sure why there are 2 different styles, but could this be the reason for an overheat? Are these wrong gaskets? I have the manual but it's not clear
Puzzled....still!
-BAproject
Puzzled....still!
-BAproject
