exhaust "run-off" after decarb
elwopo
Hello all,<br />I used spray decarb on my outboard this weekend. I set the motor up, sprayed full, and let sit overnight. When I dropped the motor to start, and turned the water on...a milky liquid (thin viscosity) started coming out from the top of the motor "shaft" below the actual engine and the center part of the prop (exhaust?). Has anyone ever experienced this...and if so...how bad is it?<br />Thanks,<br />Tony
eurolarva
Re: exhaust "run-off" after decarb
Dont worry about it. What you have is a can of decarb, motor oil and gas mixed with water coming out the exhaust. It will quit when all the decarb is burned off. This is normal
