Spiderhole
- Joined
- Oct 29, 2014
- 118
Good afternoon, I have a question about a new (86' 4Winn's) boat that I just came into. I am fairly familiar with the 4.3L Mercruiser motor and alpha one outdrive. This has the Gen I Alpha One. Before I drop it into the water I decided to do a full maintenance on the boat and inspect as much as I can. I decided to replace the exhaust manifolds and risers as it still had the original. It has exhaust shutters that are different the the ones I've seen in other Y pipes, and I was hoping you guys could tell me if what I am looking at is correct. The other ones I had were literally like two spring loaded flaps. These seem to just sit on a rod that goes through them and just kind of hang there. I found the replacements online and they look identical. Is this correct? Also, one of the boots had a small rip that only goes as far as the first tie down - I don't think it will leak if I clamp the two of them down, but I wanted to see if it is even possible to get a replacement boot?
