Hi ,
I have a 2012 V8-300 CE A that runs at normal temperature at planning speed (174 degrees) but when it goes down to idling the Exhaust temperature alarm goes off .
This engine has a closed loop system ; Ive had the Heat Exchanger cleaned , thermostat replaced, new circulating pump and raw water pump.
Per the online diagram it seems that this particular engine runs coolant through the manifolds and raw water is directed to the elbows so the manifolds should be in good shape. (boat has 170 hours mostly used in fresh water; only two years in salt water).
Ive checked the manifolds temperature with an IR gun and it is around 200 F at idling which seems high but I know that CAT engines run hotter.
Therefore I wonder if somebody knows the trigger temperature of the manifold sensors used in this particular engine to rule out a possible sensor problem.
TIA!!
TIA!!
