Gilded_Splinters
- Joined
- Jul 25, 2012
- 64
Good Morning,
Had some trouble last night on a slow cruise with my wife.
I have twin 1990 OMC Cobra 5.7s. We cruised at a relaxed 1600 RPMs for a while, the boat was running nice and cool. There was a sudden tapping sound that seemed to indicate trouble. Within seconds the boat was billowing smoke from in the engine compartment, in the cabin, etc.. The boat immediately lost power in the starboard engine and I shut them down. Mind you this all took just a few seconds.
I opened the hatches. let the smoke clear and ensured that we were not on fire. What I found was a roasted rubber exhaust connector, the one attached to the riser. The tapping sound was the exhaust leak apparently. I have to assume that there was no water there at all, but I was bringing water on board via the raw water pump and the other side was intact.
The really odd thing is that the temp gauge read only a few degrees above normal. The gauge and sender do work.
After things cooled down a bit I briefly started that engine and the exhaust leak notwithstanding, it didn't sound too great, nor was it running well. The oil seemed OK, not burnt smelling or in appearance.
I'm going to get back in there tonight. Any thoughts? I suspect the manifold or an obstruction between the thermostat housing and the manifold.
I should mention that I put new risers on it last year as they were very clogged, but the manifolds looked OK at that time.
