One Evinrude 60hp twin, 1983 model, bought this last week with a weak tell tail. Cleaned the tell tail and tube back to the head, replaced the impeller, its housing and all the associated gaskets etc, (the old impeller was new, if that makes sense) Started it in a drum with the water about 2 inches over the level of the impeller, still got a bribble coming out of the tell tail. However, on intially starting it up i noticed what appeared to be exhaust coming out of the tell tail and when the bribble arrived the exhaust was still evident. Is this normal ? have I got a blockage in the head causing low water pressure out of the tell tail or a blown head or head gasket as surley the cooling water shouldnt be mixing with the exhaust. Any help appreciated. Cheers Rob
