exhaust
Dhadley
Re: exhaust
Welcome!!<br /><br />Lets hope water comes out there! <br /><br />Yes, its fine -- no problem at all. What size motor is it?
bnk999
Re: exhaust
That is a water cooled engine, it sucks water up from the bottom of the motor leg and pumps it thru the motor and out along with the exhaust. If you don't have water coming out that means your impeller is not working and you will overheat your motor.....
Moody Blue
Re: exhaust
Good news new-2-boats. Seems to be working fine so far. Lets hope your luck holds out.
new_2-boats
Re: exhaust
ok not my cooling hole, there is two holes were exhaust comes out and there is water sputtering out. I also have gas coming out a hole behind the fuel pump, any ideas?
Moody Blue
Re: exhaust
Not to worry, this is normal.<br /><br />
This is bad. You need to rebuilt the fuel pump and use all new gaskets.
JB
Re: exhaust
Moving to Johnson Troubles.
