tperk100
- Joined
- Oct 10, 2009
- 84
I have a 50 gal metal tank. Right or wrong, for winter storage I filled the tank ALL THE WAY UP to the top of the fill tube with treated gas. Then I ran the engine for a few minutes and observed the fuel level going down in the fill tube.
A week of so later (on a relatively warmer day) the gas was overflowing out of the fill tube. I attributed this to warm weather expansion, so I siphoned FIVE GALLONS of fuel out of the tank.
Problem solved....so I thought. Yesterday (a warmer day also) the fuel was overflowing again! Now I have already taken over 10 % of the fuel out of the tank. Could it possibly be expanding this much? I doubt it.
Friends have tried to convince me I have a venting problem. The tank appears to be vented through the fill tube cap. Here is a link to the Perko cap. You can see it has a connection for the vent. So, if here is any venting of gas, it seems its supposed to discharge through the cap and run all over the boat rub rail as it has been doing. (destroying the rub rail to hull sealant)
http://pdf.nauticexpo.com/pdf/perko/marinium/21871-2826-_6.html
I can see that the actual vent tube is attached as it seems to be intended.
Can anyone shed any light on this? Will gas expand this much? Any other thoughts / suggestions?
Thanks much.
Thanks much.
