expected compression
smyers1115
what compression should a 1957, qd-18, 10 hp johnson have. i can only get 30psi. thank you
Chinewalker
Re: expected compression
By any measure, 30psi would be low - UNLESS your gauge is not seated properly. Ideally, I'd like to see at least 85 psi in each cylinder, with a less than 5% variance between them...
- Scott
