explenation of ID number
EvinZodiac
Hello all,<br />I'm trying to recover the mod number by partnumbers at the BRP cathalogus site and sofar I discoverd that the number at the vro pump only is been used on 1991 and 1992 models (evinrude v4 90hp?) but now is my question :confused: : the T at the begin of the modnr means Tracker or V -boat builder. What is a Tracker and what are the difrenses with the normal factury build models. Is it the colors or other things?<br />How can I see if it is a commercial model (WT)<br />With the answers I can make my list with modnumbers eatch time a little bit smaller.<br />Thangs already for your answers. this forum is great :)
OBJ
Re: explenation of ID number
OMC once powered all of the Tracker line of boats. They are most popular in Bass Pro Shops catalogs.<br /><br />The only difference I've seen is the black tracker color and "Tracker" on the hood of the engine. The engines are the same.<br /><br />If your looking for the model number of your engine, look on the engine block for a large welch plug. The model and serial number should be on there. And it should also be on the port transom bracket on a little metal plate.
EvinZodiac
Thanks OBJ,<br />This shortnes the list a lot, now I know what a tracker is<br /><br />I found the plug but there is only the serial number and at BRD they can't find anything. The plate on the side of the bracket is missing. and the other welch plug has a Q on it?<br />So I think it is Belgium made.
