MrGED05
- Joined
- Jul 25, 2008
- 50
Rebuilding a '73 Johnson 9.5 hp Carb. Ordered the manual a week ago but it hasn't arrived and I've a three day weekend in which to complete the task. Figure it should be "doable" without the manual.
I have the proper rebuild kit (PN 0382048).
Float, needle valve and seat, those are now as they should be. Float set to be level with carb top when inverted, 1/4 inch drop opens the valve nicely. The kit contains carb top to float bowl gasket and carb to intake gaskes that match what I've removed.
However, oddly enough, I've one package of replacement bits and pieces that don't match with anything I've found inside the carb. There is a circular screen, several small round gaskets, and a cork plate gasket that don't match anything inside the carb. One black plastic rod, about 1/16 inch diameter, about an inch long, slotted and hollow head is a real interesting piece, no idea where it belongs.
A "exploded view" of the carb would really help me identify and properly replace these.
Anyone have an "exploded view" or diagram of the carb they'd care to share with me? Or a hit about where these parts are located in the engine?
Thanks in advance,
Gary
Thanks in advance,
Gary
