Expressionless Force?!
walkingfish
Hi,<br />Sorry about the strange header,<br />1989 Force 125 Hp<br />What my motor wants to do is make itself heard/seen!<br />I have only a rev counter, and maybe a buzzer (but i don't know if it works!)<br />Is it possible/easy to wire in extra gauges?<br />I was thinking of Water Pressure, Temperature, and Trim gauges.<br />Can i buy generic gauges and fit them myself?<br />Will i have to buy the sender units as well or has the Force got them already and only needs the gauges and wires?<br />Are there any other gauges i should consider?<br /><br />Hope someone can help out, as i want to have the motor wired up like its in hospital (just in case)<br /><br />Big Fish, Small Expense
<br />W'fish
wesal1
Re: Expressionless Force?!
I know the water preasure is very ez to install you put a tee in the **** hose and run it back to the gauge
mikec
Just wondering, what is the range of pressure we should see in the cooling system? (OMC) Dont think Ive seen it in a spec...
