extra drain hole in the transom
keeman7
I just bought a 16' Crosby fiberglas project boat. It's not in too bad of shape. It looks to me like the floor has already been taken out. You can see outline of short stringers up the bow. The thing that has me puzzled is that there are three drain holes in the transom. One up high for the splash well and two at the bottom of the transom. One drains the floor area that is now bare and another one about two inches below that at the very bottom of the transom. Is there another floor below my bare floor. I don't think there's room for one but what is that other drain hole???
tashasdaddy
Re: extra drain hole in the transom
picture would help. you can up load to a free service like photobucket.com then you choose the pictures you want( clik the little box at the bottom left of the picture) scrool to the bottom of the page, clik generate html, it will take you to the next page, scroll down to thumb nails clik on that and copy, then insert it into your post.
also if you are planing on posting pictures, you can use the Blue post reply or the go advanced, manage attachments, there you can upload , directly from your computer. besure you pictures have been resized to fit the format. 640x480 max.
*EdC*
My MFG has the same setup, Any water that gets between the floor and the bilge, drains out there.:)
a70eliminator
Yes there is a space below the floor, if your hull were ever to leak that space would fill with water and if there are any cracks or holes in the floor your boat will sink, if your floor is sealed tight you would be ok. I usually pull that plug after each outing just to verify there's no water in there and nothing leaked.
