Has anyone ever used a Fram Sure Drain oil valve? It replaces your oil pan bolt with a quick connect female fitting that a hose with a male fitting can plug into for quick draining. My oil change pump broke and I don't want to spend another $45 for one if this will be even easier. What I was thinking was to put the valve in and just run the hose through the hole that the boat plug goes and have a pan there to catch the oil as it comes out! Seems like it would make oil changes faster and easier than pumping forever the old way. Does anyone have any thoughts they can share with me on this?
