EZ Question - what type of oil goes in the trim pump
Don S
Re: EZ Question - what type of oil goes in the trim pump
Some kind of oil............ :rolleyes:
Trim pump for what, your question as asked, is un-answerable.
ziggy
ya could read this. though it still won't answer yer question..... but it'll sure help everyone else that might want to answer the question... http://forums.iboats.com/showthread.php?t=220416
that's from the adults only sticky at the very top of the i/o fourm. it has lots of good info in it...
AZSenza
I'm going to assume you are speaking of the engine trim on a mercruiser i/o such as an Alpha or Bravo, if thats not what you are talking about - Its NOT 30w engine oil but it is if thats what you are reffering to.
Please check your engine manual first though, I dont know everything!
What type of oil goes in the trim pump.
Ayuh,... Pretty much ANY light weight oil.....10W is Best(ATF, P/S. fluid),... 30W will Work...90W is Too Thick...
bigskiohio
Mine says 20 weight motor oil
Mkos1980
My Mercruiser mini Manual from 1990 says 10w30 and thats what I've been running with no issues.
