jstrat7804
- Joined
- May 12, 2010
- 111
WOULD LOW OIL CAUSE THE ENGINE TO GO INTO S.L.O.W ? the book says no. engine is getting plenty fuel and oil was low, sorry its a 1990 225 rude, checked pulse limiter its blue, ran at low rpm fine alarm would only go of at around 3000 RPM.DID just do a decarb prior to this happening, have a 6 gallon tank with 100/1 ratio ready to go to see if its the main tank problem. last thing should i pull the pulse limiter and clean anyway?
