jack daniels marine
- Joined
- Jun 27, 2012
- 48
Hi folks.
My F100 is 9 years old and has probably still contains the original tilt oil, so I want to replace it completely while the boat is on a trailer. This motor has just 1 piston.
Is suction the only way to get the old oil out? in which case will this sequence work ok?:
1. suck ( with motor up )
2. refill
3. tilt up/down to mix the old and new oil
4. repeat until the oil sucked out looks ok.
or will lowering the motor with the fill plug removed expell oil ?
2. refill
