F100 trim not working
budimus
2001 Yamaha f100 trim will not go up or down. Motor is running and full of fluid. Will go up and down on the bench but not when on the boat. Any suggestions would be appreciated
DangarStu
By "motor is running", do you mean that you can hear it whine while you try to lift it on the boat? If not, then I'd be going through all your wiring for the switch and relay on the boat. If you can hear it moving, then maybe the bypass valve is slightly open meaning that it can't lift the weight of the motor?
Stuart
