Thank you for your answers about VST.
I have just replaced crank shaft gasket on my F115 because of water in cylinder and oil, I cleaned also injectors(they work perfectly) and valves and salt in crank shaft (all that can be cleaned !), it is like new now. Before I do this job my F115 ran perfectly at idle. Now it runs perfectly and better (more power) at mid range and full power, like it has never ran before.
But at low rpm I have problem with idle, randomly. Rpm increases to 900 and decreases to 600 randomly, and sometimes motor dies. It seems that electronic try to maintain the good idle (before it was 700 rpm stable).
When I start it again, no problem, idle remains stable (700) and then, after a few minutes, problem remains.
I saw on this forum the same problem and it seems to be filter in VST, it is why I asked the question (see post "what is VST?")
BUT perhaps, someone has another idea ?
Many thanks
Lo?c
FRANCE
Many thanks
Lo?c
FRANCE
