If anyone can help I would greatly appreciate it. I have twin 2003 F200s with 450 hrs each and the port motor has developed a knocking/rattling sound when the motor is running above idle. It does not occur at dead idle but it almost always occurs when the engine is run (in gear or in neutral) above idle RPM. Almost like a harmonics vibration noise but i doubt thats it. The noise started early this season (about 30 hrs ago) and it may be getting a little louder but it's hard to tell. Even when the motor is making the noise is seems to be louder at some RPS and quiet or gone at others although, when I am running fast all the other noises make it hard to tell if the knocking rattling sound is still there. Also, the last time I ran the boat (20 minutes to get fuel) it did not make the noise at all. This was odd because, other than this trip, the noise is fairly consistent. The performance of the motor does not appear to be effected and it is otherwise running fine - good stream of water out the pisser hole and everything.
I made two 1-minute videos (one in gear and one in neutral) so people can hear my starboard motor (sounds fine) and then my port motor (with the noise i describe above). you can see the videos at the two youtube links below:
http://www.youtube.com/watch?v=_83jGwXJ4n4
http://www.youtube.com/watch?v=Xbh0bVvPAWk
Thanks much for any assistance anyone might have.
Michael
Michael
