andymach23
- Joined
- Mar 9, 2005
- 156
I have a F80 (Same as the US F75/F90 I think!) on my new boat. The engine is year 2000 and has been used in salt water.
When I connected the hose up to my F40 on my old boat the water came out of the tell tale under pressure, basically as fast as the hose was turned on.
On the F75 engine, with the hose full on, there is a very little pressure from the tell tale. There is a lot of back pressue at the hose as the connector leaks. There is some water running out of the lower leg as expected. There seems to be alot of restriction going on somewhere in the engine.
Should the water exit the tell-tale under greater pressure, as per the F40? The very weak tell-tale flow, combined with the back pressure just doesn't seem right.
Cheers
Andy
Cheers
Andy
