F9.9 alternater on Yamaha?
Capn Mike
OK, here's a dumb question: when I bought my boat, the dealer installed a used '88 9.9 high-thrust Yamaha 4S, electric start as a kicker on my boat. Near as I can figure out, he hooked it up directly to the battery switch. Works great, thank you, and starts everytime. Of course, when I'm running it, I turn off the ignition on the main engine (200 Johnson). When the kicker is running, I've turned the ignition key to "on" and noticed the amp gauge shows 14+, so the kicker must have an alternator working. <br />My question is this: is the Yamaha kicker also charging my battery, and if so, what's the output? I don't have a manual, so am not sure if my batteries are being drained while the kicker is running alone.
WillyBWright
Re: F9.9 alternater on Yamaha?
The 4-stroke 9.9s have battery charging capabilities as far as I know, but not sure of an '88. It would be nice if it did, but the motor won't drain the battery while it's running. It produces it's own power for the ignition. The only draw would be from the starter and electric choke.
