Hi all, I have this factory setup trailer (Magic Tilt) under a Twin Vee 17' power catamaran (785lbs hull only) and nothing seems to be right with it.
The first Issue I have is the tongue weight seems to be tremendous, I am unable to lift it (im guess over 200lbs+) It even feels heavy when cranking the jack. Makes the rear of my car drop to the ground basically its so heavy. The stern of the boat is over hanging the trailer frame by 12 inches total and about 6" off the unsupported area of the end of the bunk, I think I can forget about moving the boat foward on the trailer. Over all length of the trailer is 19ft I measured.
I looked under the coupler and saw damage I am thinking this trailer was hit and then cut to the good meat and the coupler was remounted. Not sure, see picture. Could explain why the trailer seems so short for the boat and there is so much dang tongue weight?
Another rant the bunks seem setup terrible 10' of carpeted bunks with alot of the hull touching at the sharp corners of the bunk wood. I will do another thread for this when I am sure I can keep the trailer or not.
Here is a website with reference pictures with the same boat on factory trailers. I am sure mine is a factory trailer the model # is the same name as the boat according to the stickers on the trailer.
http://www.powercatboats.com/17cc_pics.htm
Here are some pictures of my boat on its trailer.
Thanks all!
Thanks all!
