hamishmcduff
- Joined
- Jun 16, 2010
- 28
This is looking into the Thermostat housing.
Engine is 250ci 165 hp L6
The San Juan heat exchanger failed.
see this > http://forums.iboats.com/showthread.php?t=576899&highlight=coolant+replaced
I will have to purchase a new one in the spring, but what can be done to fix this mess?
There is sand and scaling in there!!!
I figure I could flush out the system a few times with some chemical additives, replace the water pump, all new H/E ofcourse.
I did a compression test and all cylinder were within 5 psi highest was 180.
I told myself I would not tear this engine out this year if the compression was good.
