fancy greases when rebuilding...
JT!
do i absolutely need the various greases recommended in the shop manual for a powerhead rebuild?
like: "2-4-C with Teflon"
i have 2 stroke oil for metal parts, and light lithium grease spray to apply to the seals, etc. is this enough?
will my motor self destruct because of this plan?
Chris1956
Re: fancy greases when rebuilding...
It kinda depends on what motor you are rebuilding. Most Mercs need aome multipurpose grease to stick the rod and pin bearings into place. That an 2 cycle oil will see you thru. Some motors want locktite and perfect seal. There are substitiutions for the pricy OEM stuff.
