Fast Idle Lever Barely Works '96 Johnson 88 hp
Tinman57
The fast-idle lever on the control box seems very loose, and it hardly boosts the idle speed at all. When I remove the motor cover and work the fast-idle lever, it barely moves the throttle linkage, and barely revs the engine. The fast-idle lever seems completely loose in the first 40 degrees of travel. In the last 5 degrees it finally gets a bit of tension and moves the linkage.
All was working fine last week and the fast-idle lever boosted rpm quite a bit, as it always had. This is a sudden change. I also notice that the engine sometimes seems to take a long time to idle down from high speed.
Engine model is J88TSLEDR
