Fast Idle Lever
Cadwelder
The fast idle lever on my control box won't increase engine speed. It basically does nothing. Is there a quick fix to look for here or just take the control box apart and look see?
redjmp
Re: Fast Idle Lever
Yup!
But first disconnect the cable from the carb and check to see if the cable moves then when you move the lever.
It doesn't move much and if the linkage is out of adjustment the carb will not open any ...
Cadwelder
Re: Fast Idle Lever
Thanks for the help, turns out I just wasn't lifting up hard enough. It takes more pressure to work than I thought.
