Fast Idle stays on
CoastalPete
After fixing the timer base my idle is staying high for a long time before it kicks down, any suggestions? The port side head is still much cooler than the starboard, maybe I should check the temp. sensor or check for something clogged?
Thanks,
Pete
Daviet
Re: Fast Idle stays on
Is the timer base binding and not rotating freely?
Chris1956
Do you care to tell us what motor you are working on? it would appear to be a v engine. If that is the case, the heads should run about the same temp. Sounds like thermostats are suspect at least.
