i just replace all 4 fuel pumps on twin '88 150 yamaha 2 strokes.<br /><br />with the old pumps, both motors idled at 800 rpm, with new pumps, one is a 1000, the other at 900. since nothing else changed, should i assume timing is fine and adjust the idle screws? or should i check timing to be thorough (i know it's quick, but i don't have a timing light). it it common for idle rpm to rise after replacing pumps?<br /><br />also, i was concerned about possible lean condition (dirty carbs) due to a few backfires on initial starting. i attributed that to all the fogging oil in the carbs, since they started fine after running a while. would a fast idle be further indication that carbs are clean?<br /><br />thanks!
