glenn property of pam
- Joined
- Feb 17, 2012
- 2,906
Mr joe reeves says before timing if you have fast start you must disable it. So what is fast start, how does it work and how would you disable it if you did have it.
Its a feature that uses 9volts from timer base to pack to advance timing around 6-9? to ensure reliable starts. When cylinder head temp reaches 96? it kicks out. It activates for 5 seconds every time engine starts regardless of engine temp.So what is fast start, how does it work
Ground the white /black wire on cylinder head to block.....how would you disable it if you did have it.
