Hi,
First post. I have a fine little 28 that seems to want to run more on 1 cylinder than 2. It won't idle or run slow without stalling and occasionally will stay in 1 cylinder mode all the way to WOT for a minute or 2 until it clears. Naturally I suspect the ignition to be bad.
Unfortunately, I can't seem to get the flywheel off. The retaining nut came off without any difficulty, but I can't get the flywheel pulled.
I have a harmonic balance puller with a 1/2" center bolt plus I picked up the obligatory 1/4 X 20 grade 8 bolts mentioned in the forums. I have sprayed some penetrating oil on it over the course of a couple weeks. Once I have the puller snugged up tight, I add a piece of pipe to ratchet and have exerted quite a bit of force. So much force that the 1/2" center bolt on the puller deformed at the bottom and only the section above the puller is turning. I can pull on it harder, but that would only snap the bolt.
Everything in the forums I've read make this sound like a simple task if you have a puller. I never expected that I would break a puller. I figure I must be overlooking something.
Any help would be appreciated!
LC
LC
