grizzrider09
- Joined
- Jun 20, 2012
- 54
I have been working on this motor for a while now. The compression is 85 on top and 84 on bottom. I have replaced the coils and have great spark. I have cleaned the carb three times now and it will crank every pull but won't idle. It will run if you crank in gear and gas on it. After I cleaned and rebuilt the carb I'm not sure if I have the top needle in correctly. There are threads on the needle and a sort of bushing that threads on there. What I'm not sure of is this bushing is supposed to be threaded closer to the needle point or the nut that holds the needle in place. I'm out of ideas and I will post pics tomorrow if needed and if anybody has pics that can help me it would be much appreciated. Thanks
