Hi, I have done searches but didn't come up with much. 5.8 cobra , and I want to change the oil, can I do this just like!e you do a car ? Also, I want to change the fuel filter , can I just twist of the old and twist a new one on? The guy before me had a new lower unit installed right before I bought it and I think the cables need adjusted because sometimes it's tricky to find d neutral and sometimes clunks going into drive but not everytime. How hard is the adjustment on these or should I have a shop do the adjustment ? Lastly, I have a three blade prop thats a 17 pitch and I wanted something that will help me get on plan better with more of a load in it. Just two guys and it's right on plane but with four it takes a second, maybe that's just normal because I'm new to boats . Thank you for your time!!!
Howdy,
We're going to need more info on what you have. There have been many changes in the Cobras from 1986 to 1998 when OMC went out of business.
1. Oil filters and fuel filters are pretty generic. You're on the right track there.
2. shift adjustment is pretty important, but we must know what you have, Dog-clutch, Interim cone-clutch or SX. Without knowing your model number it's impossible to proceed.
3. Propeller selection. In general, propeller diameter and pitch are (somewhat narrowly) determined by how you want to use the boat and the maximum recommended RPM (range) your engine operates.
I. E. just about all engine manufacturers suggest "propping" for a WOT [wide open throttle] RPM of MAX when operating the boat loaded with full fuel, and typical load (people, dogs, gear, etc) at the pressure altitude (i.E. Lake Tahoe 6200 MSL altitude.......or Sea level) you will normally run the boat. (this assumes the boat is loaded for proper CG [center of gravity] I.E. you don't have 4 300-pounders sitting on the transom!!......... and trimmed [drive-angle] for max speed)
There were some max RPM differences from different models over the years...... 200-400 RPM can make significant difference in top speed and holeshot if you prop to the wrong max RPM.
ALL the above parameters are of course dependent on whether the engine is optimally tuned and running correct (timing, plugs, EFI, worn out etc)
In general, you'll get a little better holeshot (good for towing wake boards and skiiing) if you use a 4-blade prop as opposed to a 3 blade but it will be a little slower for top speed.
Here's examples of 5.8 OMC model numbers
584AMLMED 1989
584APRMED 1989
584AMLPWS 1990
584APRPWS 1990
584APLRGD 1991
584APRRGD 1991
584APLAMH 1992
584APLAMK 1992
584APRAMH 1992
584APRAMK 1992
584DPEAMH 1992
584DPEAMK 1992
584APLJVB 1993
584APRJVB 1993
584DPEJVB 1993
584DPPJVB 1993
58FAPEJVB 1993
58FAPLJVB 1993
58FAPLJVN 1993
58FAPPJVB 1993
58FAPRJVB 1993
58FAPRJVN 1993
58FBPEJVB 1993
584ACPMDA 1994
584AGPMDA 1994
58FACPMDA 1994
58FACPMDM 1994
58FAGPMDA 1994
58FAGPMDM 1994
58FBDPMDA 1994
584APHUB 1995
584APHUE 1995
58FAPHUB 1995
58FAPHUE 1995
58FBPHUB 1995
58FBPHUE 1995
584APNCA 1996
584APNCS 1996
58FBPNCA 1996
58FCPNCA 1996
58FCPNCS 1996
Once you determine what you have, you can find part numbers at
http://epc.brp.com/
Regards,
Rick
