Hi
My boat (fiberglass century arabian 19ft)
has a seperation in the hull, It is like there is a inner hull and a outer. On the left side rear, When inside the boat you can push on the inner fiberglass side and it moves seperatly from the outside. Seems like there are 4 layers in the hull :
from inside out, Chop? then about 1/2 inch of some type of foam, then the Fiberglass Cloth/weave? Then the outer gelcoat, The foam and the fiberglass are no longer bonded. Seems like the chop? on the inside crack along the seem where hull and topside join, Any Idea's on how to fix this?
Can I just cut the chop? (I'm calling it chop but not sure what it is, random stands of fiberglass no pattern) About a inch below the crack and glass cloth in to repair it? should I run son type of resin down between the foam and outer hull to get them to adhere? The chop is atached to the foam pretty good.
Thanks in advance for any suggestions/help
Lou
Lou
