Re: Fiberglass or aluminum
Aluminum hulls are limited in design because of the material and are lighter, this can make for a harsh ride in rough water, it can also limit how they handle at higher speeds. With constant pounding aluminun can fatigue and develope stress cracks, these cracks are not as easy to repair as the ones you may get in fiberglass. <br />They can be louder and colder.<br />But being lighter you need less HP to get good performance and it's easier to tow. you can leave it outside for years and may only have a small amount of wood to replace if there is some rot.<br /><br />Fiberglass hulls can be designed to do just about any task well, not that one design does all things well, but you are not as limited by the material, so you can design it to do what you want it to do. They are heavier and with a better shaped V in the hull, can ride smoother in rough water. Repairs can be done fairly easily at home with supplies from the hardware store or auto parts store. <br />The wood in it will rot if left outside unprotected in the weather and will be difficult to replace. <br />you will find more fiberglass hulls to choose from in that size range.<br /><br />After saying all that, just get the boat you like the best, or the wife likes the best. Most aluminum boats in that size are not sexy looking, so she may not want to go out on it with you, that can be good or bad. <br />I have aluminum and fiberglass boats and have no problem with either type.
