Trying to repair 2 small screw holes in the bottom of the boat. Ultimately mine from replacing the floor. Don't believe this is the main source of leakage though. Found a couple in the transom which have since been sealed with epoxy resin. From the research I've done fiberglass isn't actually waterproof though. I'm supposed to use a gel coat. Exactly what is a gel coat and is it readily available?
The boat is still out of the water and upside down after sinking so any help or advise would be greatly appreciated.
