Hello everybody, after getting my 95 Glasstream Yamaha build straightened out I have another project. I just acquired a 1998 Glastron SE175 with a 3.0 Volvo-Penta.
The Glastron has fiberglass, foam filled stringers (VEC?). I have searched a bit and found quite a few posts about who does it, benefits of it and when it was done but I couldn't find anything on what can be done if the foam has moisture in it? The previous owner had removed the floor and left it exposed to the elements. Since Glastron didn't seal the holes where they added the foam the foam has moisture. Right now the stringers look ok and don't appear to be delaminating but what can be done about the moisture in the stringers? I drilled a couple holes in the base of the stringer in the engine bay. There's no water gushing out but the foam is definitely wet.
My thinking was maybe I could cut the top off of part the stringers, remove the foam, glass the tops back on and refill them with foam but I dont know how this would effect the integrity of the boat. Its only a 3.0 4 cylinder so it's not going to get any real stress from the engine like my 19 ft with the 5.7 Yamaha.
What are your thoughts? I realize the boat may not really be worth it but its a hobby.
