unhip_crayon
- Joined
- Jul 3, 2007
- 53
Here is the basic design of my stringers:
I've got 1.5 oz mats and as I was lying them down and cutting them to shape, i noticed that due to the long strands i was using, the mat were not lying flat in some sections and was worried that this may cause problems when glassing(bubbles?). Should i just cut the mats into thinner strips? If so whats the pattern i should maintain? (ie. slightly overlap, or do like a brick laying pattern)
Also, will two layers be sufficient enough? All i need is to keep the water away from the wood. I've glued the stringers in with special adhesive and there rock solid, so strength isn't an issue.
Thanks
Thanks
